FYI
Here are also several other commands (ControlDefinition Names)  for AEC Exchange you might find some use for while working in that environment:
AEC_Exchange:Command:AuthorComponent                  Author Building Components
AEC_Exchange:Command:Connector:Add                    Add Connector
AEC_Exchange:Command:Connector:Cable                  Cable Tray Connector
AEC_Exchange:Command:Connector:Conduit                Conduit Connector
AEC_Exchange:Command:Connector:Delete                 Delete Connector(s)
AEC_Exchange:Command:Connector:Duct                   Duct Connector
AEC_Exchange:Command:Connector:Edit                   Edit Connector
AEC_Exchange:Command:Connector:Electrical             Electrical Connector
AEC_Exchange:Command:Connector:IncludeChildren        Promote Component Connectors
AEC_Exchange:Command:Connector:Link                   Link Connectors
AEC_Exchange:Command:Connector:Pipe                   Pipe Connector
AEC_Exchange:Command:Connector:Suppress               Suppress Connector(s)
AEC_Exchange:Command:Connector:Unlink                 Delete Link
AEC_Exchange:Command:QualityCheck                     Design Quality Check
AEC_Exchange:Command:ShareDesignPackage               Export Building Components
AEC_Exchange:Command:UploadToC360Wrapper              Upload to Configurator 360
AEC_Exchange:Environment
AEC_Exchange_Command_Include_Connector                Include Connector
AEC_Exchange_Command_Shrinkwrap                       Shrinkwrap Substitute
AEC_Exchange_Command_Source_Component                 Source Component
Wesley Crihfield
(Not an Autodesk Employee)
