- Mute
- Permalink
- Report
All,
Good morning! I've been trying to automate the creation of some BIM Connectors and am tantalizingly close, but cannot quite seem to figure out how to properly pause the code to allow users to edit the connectors. I've been playing with the .Execute2(False / True) command, but must be missing something. Please see the video below and the attached part file and I would truly appreciate any suggestions that you have! Full disclosure, I'm not a programmer, so feel free to poke fun at my code, which I already know I'll have to clean up. Thanks in advance for any help, hope all is well and have a most blessed day!
Peace,
Pete
Please give a kudos if helpful and mark as a solution if somehow I got it right.
- Mute
- Permalink
- Report
I expect the problem here is that the form is on a seperated thread. the only way i could think of to stop the main thread by creating a endless loop afther the execute command. and then look for document change events. And then break out of the loop if the event was triggered. I have some code to do this but the code is not working. Probably i forgot something small. My son just woke up so i have to take care of him. I will have a look at it later. Or maby some one else has a better solution.
Jelte de Jong
Blog: hjalte.nl - github.com
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
FYI
Here are also several other commands (ControlDefinition Names) for AEC Exchange you might find some use for while working in that environment:
AEC_Exchange:Command:AuthorComponent Author Building Components
AEC_Exchange:Command:Connector:Add Add Connector
AEC_Exchange:Command:Connector:Cable Cable Tray Connector
AEC_Exchange:Command:Connector:Conduit Conduit Connector
AEC_Exchange:Command:Connector:Delete Delete Connector(s)
AEC_Exchange:Command:Connector:Duct Duct Connector
AEC_Exchange:Command:Connector:Edit Edit Connector
AEC_Exchange:Command:Connector:Electrical Electrical Connector
AEC_Exchange:Command:Connector:IncludeChildren Promote Component Connectors
AEC_Exchange:Command:Connector:Link Link Connectors
AEC_Exchange:Command:Connector:Pipe Pipe Connector
AEC_Exchange:Command:Connector:Suppress Suppress Connector(s)
AEC_Exchange:Command:Connector:Unlink Delete Link
AEC_Exchange:Command:QualityCheck Design Quality Check
AEC_Exchange:Command:ShareDesignPackage Export Building Components
AEC_Exchange:Command:UploadToC360Wrapper Upload to Configurator 360
AEC_Exchange:Environment
AEC_Exchange_Command_Include_Connector Include Connector
AEC_Exchange_Command_Shrinkwrap Shrinkwrap Substitute
AEC_Exchange_Command_Source_Component Source Component
Wesley Crihfield
(Not an Autodesk Employee)
- Mute
- Permalink
- Report
I have a code that is working in Visual studio. But when i copy it to an iLogic rule it does not work for the 2e connector. it looks like your previous problem. the connector does not get selected. therefore executing the edit command does not work. (i left 2 msgboxes in the code that will help you see it.) Anyway im trying to get it to work for a couple of hours now and i realy need to get to bed. but here is what i have so far. Maby some one else is seeing why the 2e connector is not getting selected.
Public Class ThisRule 'Private Shared docEvents As DocumentEvents Private busy As Boolean = False Sub Main() ' Get the collection of control definitions. Dim oControlDefs As ControlDefinitions = ThisApplication.CommandManager.ControlDefinitions ' check if this document is a part document If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then MessageBox.Show("The current document must be a part file", "Incorrect Document Type") Return End If 'Enter the BIM Content environment ThisApplication.CommandManager.ControlDefinitions.Item("AEC_Exchange:Environment").Execute() 'Access the Browser and Activate the "Bim Content" Browser Pane Dim oPartDoc As PartDocument = ThisDoc.Document Dim bps = oPartDoc.BrowserPanes Dim bimContentPane As BrowserPane = Nothing For Each BP As BrowserPane In bps ' the name is case sensitive original it worked only accidentally (BIM should be with capital letters) ' ' i made the if statement case insensitive ;-) If BP.Name.Equals("Bim Content", StringComparison.InvariantCultureIgnoreCase) Then BP.Activate() bimContentPane = BP End If Next 'Define the Appearance variables Dim oElecAppearance As Asset = oPartDoc.Assets.Item("Connection_Electrical") Dim oMechAppearance As Asset = oPartDoc.Assets.Item("Connection_Mechanical") Dim oPipeAppearance As Asset = oPartDoc.Assets.Item("Connection_Piping") 'Define the BIM Component Information Dim oPartDocBIM As BIMComponent = oPartDoc.ComponentDefinition.BIMComponent 'Check through each Face on the body and see if uses the special appearance. For Each oSrfBody As SurfaceBody In oPartDoc.ComponentDefinition.SurfaceBodies For Each oFace As Face In oSrfBody.Faces If oFace.Appearance.DisplayName = oElecAppearance.DisplayName Then Dim Elec_Coll As ObjectCollection Elec_Coll = ThisApplication.TransientObjects.CreateObjectCollection Elec_Coll.Add(oFace) 'Create Electrical Connector Definition Dim oElecConn As BIMElectricalConnectorDefinition oElecConn = oPartDocBIM.Connectors.CreateElectricalConnectorDefinition(Elec_Coll) oElecConn.SystemType = BIMElectricalSystemTypeEnum.kPowerBalancedElectricalSystemType 'Add the Electrical BIM Connection Dim con As BIMConnector = oPartDocBIM.Connectors.Add(oElecConn) con.Name = "Elec_Conn_" & oPartDocBIM.Connectors.Count 'Create a Browser Node and select the new connector via the Browser Dim oTopBrowserNode As BrowserNode = bimContentPane.TopNode For Each oNode As BrowserNode In oTopBrowserNode.BrowserNodes If Right(oNode.FullPath, 22) = "MEP System Connections" Then oNode.Expanded = True '<-- this is an important change Dim oSubNode As BrowserNode = oNode.BrowserNodes.Item(5) oSubNode.Expanded = True '<-- this is an important change Dim oConnNode As BrowserNode = oSubNode.BrowserNodes.Item(con.Name) MsgBox("before select") oConnNode.DoSelect() msgbox("After select") 'Open and edit the new Electrical BIM Connector Dim oControlDef As ControlDefinition = oControlDefs.Item("AEC_Exchange:Command:Connector:Edit") ' Execute the command. oControlDef.Execute() Dim docEvents As DocumentEvents = ThisApplication.ActiveDocument.DocumentEvents AddHandler docEvents.OnChange, AddressOf docEvents_OnChange busy = True While (busy = True) System.Threading.Thread.Sleep(50) ThisApplication.UserInterfaceManager.DoEvents() End While RemoveHandler docEvents.OnChange, AddressOf docEvents_OnChange End If Next End If Next Next End Sub Private Sub docEvents_OnChange(ReasonsForChange As CommandTypesEnum, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) If (BeforeOrAfter = EventTimingEnum.kAfter And Context(1) = "API Change") Then busy = False End If End Sub End Class
Jelte de Jong
- Mute
- Permalink
- Report
Hi, i found the problem that i had last knight. the command form was closed but the command it self was not finished. i had to force it to stop. That did the trick. Below you find the working code. I also removed some code that could that loops over all nodes tofind the correct Browserpane and nodes. (and i used my own code from you previous question;-)
Public Class ThisRule Private busy As Boolean = False Sub Main() ' Get the collection of control definitions. Dim oControlDefs As ControlDefinitions = ThisApplication.CommandManager.ControlDefinitions Dim oControlDef As ControlDefinition = oControlDefs.Item("AEC_Exchange:Command:Connector:Edit") ' check if this document is a part document If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then MessageBox.Show("The current document must be a part file", "Incorrect Document Type") Return End If 'Enter the BIM Content environment ThisApplication.CommandManager.ControlDefinitions.Item("AEC_Exchange:Environment").Execute() 'Access the Browser and Activate the "Bim Content" Browser Pane Dim oPartDoc As PartDocument = ThisDoc.Document Dim bps = oPartDoc.BrowserPanes Dim bimContentPane As BrowserPane = oPartDoc.BrowserPanes.Item("AEC_Exchange:Browser") 'Define the Appearance variables Dim oElecAppearance As Asset = oPartDoc.Assets.Item("Connection_Electrical") Dim oMechAppearance As Asset = oPartDoc.Assets.Item("Connection_Mechanical") Dim oPipeAppearance As Asset = oPartDoc.Assets.Item("Connection_Piping") 'Define the BIM Component Information Dim oPartDocBIM As BIMComponent = oPartDoc.ComponentDefinition.BIMComponent 'Check through each Face on the body and see if uses the special appearance. For Each oSrfBody As SurfaceBody In oPartDoc.ComponentDefinition.SurfaceBodies For Each oFace As Face In oSrfBody.Faces If oFace.Appearance.DisplayName = oElecAppearance.DisplayName Then Dim Elec_Coll As ObjectCollection Elec_Coll = ThisApplication.TransientObjects.CreateObjectCollection Elec_Coll.Add(oFace) 'Create Electrical Connector Definition Dim oElecConn As BIMElectricalConnectorDefinition oElecConn = oPartDocBIM.Connectors.CreateElectricalConnectorDefinition(Elec_Coll) oElecConn.SystemType = BIMElectricalSystemTypeEnum.kPowerBalancedElectricalSystemType 'Add the Electrical BIM Connection Dim con As BIMConnector = oPartDocBIM.Connectors.Add(oElecConn) con.Name = "Elec_Conn_" & oPartDocBIM.Connectors.Count Dim systemNode As BrowserNode = bimContentPane.TopNode.BrowserNodes.Item("MEP System Connections") Dim electicalNode As BrowserNode = systemNode.BrowserNodes.Item("Electrical") electicalNode.Expanded = True Dim oConnNode As BrowserNode = electicalNode.BrowserNodes.Item(con.Name) oConnNode.DoSelect() oControlDef.Execute() Dim docEvents As DocumentEvents = ThisApplication.ActiveDocument.DocumentEvents AddHandler docEvents.OnChange, AddressOf docEvents_OnChange busy = True While (busy = True) System.Threading.Thread.Sleep(50) ThisApplication.UserInterfaceManager.DoEvents() End While RemoveHandler docEvents.OnChange, AddressOf docEvents_OnChange ThisApplication.CommandManager.StopActiveCommand() End If Next Next End Sub Private Sub docEvents_OnChange(ReasonsForChange As CommandTypesEnum, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) If (BeforeOrAfter = EventTimingEnum.kAfter And Context(1) = "API Change") Then busy = False End If End Sub End Class
Jelte de Jong
- Mute
- Permalink
- Report
@JelteDeJong, good morning! That worked perfectly and I've now adapted it to work with piping and duct connectors! I finally broke down and decided to use your code
Seriously though, I cannot thank you enough as this is now working the way that I envisioned it to. I really appreciate the help, hope all is well and have a most blessed day!
Peace,
Pete
- Mute
- Permalink
- Report
Its good that you have decided to use my code. I knew I could convince you to come to the dark side.
Jelte de Jong
