06-03-2020
07:12 AM
- Mute
- Permalink
- Report
06-03-2020
07:12 AM
Would this iLogic rule work for you?
It loops through each sheet in the drawing, then each view in each sheet, then loops through all the sketches within that views model, and when its name = "ZNACKA", it sets it to be Included in its parent view.
Dim oDDoc As DrawingDocument = ThisDrawing.Document
Dim oSheet As Sheet
Dim oView As DrawingView
Dim oSketches As PlanarSketches
Dim oSketch As PlanarSketch
For Each oSheet In oDDoc.Sheets
For Each oView In oSheet.DrawingViews
oSketches = oView.ReferencedDocumentDescriptor.ReferencedDocument.ComponentDefinition.Sketches
For Each oSketch In oSketches
If oSketch.Name.Contains("ZNACKA") Then
oView.SetIncludeStatus(oSketch, True)
End If
Next
Next
Next
I hope this helps.
If this solves your problem, or answers your questions, please click 'Accept As Solution".
Or, if this helps you reach your goal, please click 'LIKES"
Also, if you're interested, here are a few of the 'Ideas' I'd like to get implemented.
If you agree with any of them, please vote for them.
- Add more capabilities to the 'Customize' dialog box (exe. Add Tab & Add Panel) Click Here
- Constrain & Dimension Images In Assembly Sketches & Drawing Sketches (TitleBlocks & SketchedSymbols) Click Here
- Save Section View Status In DesignViewRepresentation (So It Can Be Used In The Drawing) Click Here
- Add SolidBodies Folder In iLogic Rule Editor Model Tab Click Here
- Convert All Views To Raster Before Autosave Stores To 'OldVersions' Folder Click Here
- SetDesignViewRepresentation - Fix limitations for DrawingView of a Part Click Here
- Create DocumentSubTypeEnum Click Here
- Add kRevisionTag or kDrawingRevisionTag to ObjectTypeEnum Click Here
Inventor 2020 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
