Darkforce_the_ilogic_guy
626 Views, 4 Replies
unground, relocate/offset reground
it is possible to make an ilogic code that..
1. ask how you want it to move(X,Y,Z)
2. check if the componemt is ground
3 remove ground
4. move componemt
5. reground if componemt was grounded
6. do 2-5 on all componemt
I found this code but it only move one at the time and it does not offset location but set an location. and ground no matter want .. and it use select ... witch is offen very slow . I want to do it withont select an to all componemt on firstlevel. can anyone help with this  in ilogic
'check for selection
Dim compOcc As ComponentOccurrence
Try
  compOcc = ThisDoc.Document.SelectSet.Item(1)
Catch
  MessageBox.Show("Please select a component before running this rule.", "iLogic")
  Return
End Try
' remove constraints for the selected component
Dim oConstraint As AssemblyConstraint
For Each oConstraint In compOcc.Constraints
oConstraint.Delete
Next
Dim uom As UnitsOfMeasure = ThisDoc.Document.UnitsOfMeasure
Dim convFactor As Double = uom.ConvertUnits(1.0, uom.LengthUnits, UnitsTypeEnum.kDatabaseLengthUnits)
' Get the current transformation matrix from the occurrence.
Dim oTransform As Matrix = compOcc.Transformation
X = InputBox("Enter X", "Title", "")
Y = InputBox("Enter Y", "Title", "")
Z = InputBox("Enter Z", "Title", "")
' Move the occurrence ignoring any constraints.
oTransform.SetTranslation(ThisApplication.TransientGeometry.CreateVector(X*convFactor, Y*convFactor, Z*convFactor))
compOcc.SetTransformWithoutConstraints(oTransform)
' ground the component
compOcc.Grounded = True
Tags (1)
Labels (1)
