JelteDeJong
in reply to: moraesorlando
have a look at the following iLogic code. it's not exact what you asked for but i think it is what you want. It makes a copy of the active document. Also it sets the iproperty Project to the project number that was given.
I added 2 comments in the code. At the first it allowes you to set a template file name. The other shows you where you can add extra iProperties to set.
Dim projectNumber = InputBox("What is the project numebr", "Project number", "")
Dim folderBrowserDialog1 = New System.Windows.Forms.FolderBrowserDialog()
Dim path As String = ""
If (folderBrowserDialog1.ShowDialog() = System.Windows.Forms.DialogResult.OK) Then
    path = folderBrowserDialog1.SelectedPath
Else
	Return
End If
Dim doc As Document = ThisApplication.ActiveDocument
Dim fileInfo As System.IO.FileInfo = New System.IO.FileInfo(doc.FullFileName)
' Replace the text test in the next line with something meaning full for you
Dim newFileName As String = String.Format("test {0} test{1}", projectNumber, fileInfo.Extension )
Dim newFullFileName As String = System.IO.Path.Combine(path, newFileName )
System.IO.File.Copy(fileInfo.FullName, newFullFileName, True )
Dim newDoc As Document = ThisApplication.Documents.Open(newFullFileName)
newDoc.PropertySets("Design Tracking Properties")("Project").Value = projectNumber
' set more properies here if you want
newDoc.Save()
Dim res = MessageBox.Show("File is created. do you want to close it?", "File created" ,MessageBoxButtons.YesNo)
If (res = DialogResult.Yes) Then
	newDoc.Close()
End If
Jelte de Jong
Blog: hjalte.nl - github.com
