- Mute
- Permalink
- Report
Hello
I have a top-assembly that consists of a large number of sub-assemblies. I want to go through all the sub-assemblies and look for a specific part number ( like iProperties PartNumber ="73265" ) and then return in which sub-assemblies that the specified part number is included in. How can I get in which sub-assembly that the specified part number is included?
- Mute
- Permalink
- Report
If the partnumber you're looking for is always a part you could try this rule ![]()
Dim oAsm As AssemblyDocument = ThisDoc.Document Dim oPnr As String = InputBox("Part number: ", "Enter part number", "PARTNUMBER") Dim Msg As String = "Part exists in: " & vbCrLf Dim oList As New List(Of String) Dim partExists As Boolean = False For Each oOcc As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences.AllLeafOccurrences If oOcc.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = oPnr partExists = True Try If oList.Contains(oOcc.ParentOccurrence.Name) = False Then oList.Add(oOcc.ParentOccurrence.Name) Catch 'Part is in top level assembly If oList.Contains(oAsm.DisplayName) = False Then oList.Add(oAsm.DisplayName) End Try End If Next If partExists = True For Each oItem As String In oList Msg = Msg & oItem & vbCrLf Next MessageBox.Show(Msg, "Sub-assemblys containing part", MessageBoxButtons.OK) Else MessageBox.Show("Cant find part with partnumber: " & oPnr, "Sub-assemblys containing part", MessageBoxButtons.OK) End If
Jhoel Forshav
Download my free Inventor Addin - Hole Projector
LinkedIn | Ideas | Contributions | Blog posts | Website
- Mute
- Permalink
- Report
This is probably better. This code searches for both parts and assemblies with the specified part number.
Then it returns a list of all the subassemblies (or top assembly) that contains the an occurrence with that part number.
It also counts how many of it exists in each subassembly ![]()
Dim oAsm As AssemblyDocument = ThisDoc.Document Dim Pnr As String = InputBox("Enter partnumber: ", "Search for partnumber", "000000") Dim oList As New Dictionary(Of String, Integer) Dim Msg As String = "Component count in Assembly/Subassemblies: " & vbCrLf Dim pNrExists As Boolean = False For Each oDoc As Document In oAsm.AllReferencedDocuments If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Or _ oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject If oDoc.PropertySets.Item("Design Tracking Properties") _ .Item("Part Number").Value = Pnr For Each oOcc As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc) pNrExists = True Try If oList.ContainsKey(oOcc.ParentOccurrence.Name) oList.Item(oOcc.ParentOccurrence.Name) += 1 Else oList.Add(oOcc.ParentOccurrence.Name, 1) End If Catch If oList.ContainsKey("Top level assembly") oList.Item("Top level assembly") += 1 Else oList.Add("Top level assembly", 1) End If End Try Next End If End If Next For Each oKey As String In oList.Keys Msg = Msg & oKey & " - " & oList.Item(oKey) & " st" & vbCrLf Next If pNrExists MessageBox.Show(Msg, "Found components", MessageBoxButtons.OK) Else MessageBox.Show("None!", "Found components", MessageBoxButtons.OK) End If
Jhoel Forshav
- Mute
- Permalink
- Report
@JhoelForshav Thank you for your reply. It worked well but I wonder if it possible to even find virtual components in subassemblies? In some subbassemblies have we added a couple of virtual components,
- Mute
- Permalink
- Report
This should cover virtual components aswell ![]()
Dim oAsm As AssemblyDocument = ThisDoc.Document Dim Pnr As String = InputBox("Enter partnumber: ", "Search for partnumber", "000000") Dim oList As New Dictionary(Of String, Integer) Dim Msg As String = "Component count in Assembly/Subassemblies: " & vbCrLf Dim pNrExists As Boolean = False For Each oOcc As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences If TypeOf oOcc.Definition Is VirtualComponentDefinition If oOcc.Definition.PropertySets("Design Tracking Properties") _ ("Part Number").Value = Pnr If oList.ContainsKey("Top level assembly") oList.Item("Top level assembly") += 1 Else oList.Add("Top level assembly", 1) End If pNrExists = True End If End If Next For Each oDoc As Document In oAsm.AllReferencedDocuments If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Or _ oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject For Each oOcc As ComponentOccurrence In oDoc.ComponentDefinition.Occurrences If TypeOf oOcc.Definition Is VirtualComponentDefinition If oOcc.Definition.PropertySets("Design Tracking Properties") _ ("Part Number").Value = Pnr For Each parentOcc As ComponentOccurrence In oAsm.ComponentDefinition. _ Occurrences.AllReferencedOccurrences(oDoc) If oList.ContainsKey(parentOcc.Name) oList.Item(parentOcc.Name) += 1 Else oList.Add(parentOcc.Name, 1) End If pNrExists = True Next End If End If Next End If If oDoc.PropertySets.Item("Design Tracking Properties") _ .Item("Part Number").Value = Pnr For Each oOcc As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc) pNrExists = True Try If oList.ContainsKey(oOcc.ParentOccurrence.Name) oList.Item(oOcc.ParentOccurrence.Name) += 1 Else oList.Add(oOcc.ParentOccurrence.Name, 1) End If Catch If oList.ContainsKey("Top level assembly") oList.Item("Top level assembly") += 1 Else oList.Add("Top level assembly", 1) End If End Try Next End If End If Next For Each oKey As String In oList.Keys Msg = Msg & oKey & " - " & oList.Item(oKey) & " st" & vbCrLf Next If pNrExists MessageBox.Show(Msg, "Found components", MessageBoxButtons.OK) Else MessageBox.Show("None!", "Found components", MessageBoxButtons.OK) End If
Jhoel Forshav
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Love your code. Fast and easy.
I noticed sometimes the qty per assembly is not always correct, it seems to occur with phantom parts (?)
