WCrihfield
in reply to: moraesorlando
  • Would this form be a local iLogic form (saved within the document), a Global iLogic form, or a VBA UserForm?
    • If local, what type of Inventor file would it be in?
  • How do you want to trigger this form to show? (manually, parameter change, file new, file open, file close, other)
  • Where in this process are you selecting the files that are going to be copied?  I see were you mention selecting a destination folder, where some files will be pasted to, but not where you are selecting the files in the first place.
Wesley Crihfield
(Not an Autodesk Employee)
