duncpol
in reply to: duncpol
For Content center parts inserted as "standard", I would do this:
'This iLogic demo replaces the given standard component
'with another member from same family.
' row number of the new family member .
Dim NewRow As Integer = 10
'active assembly s
Dim oMainAsm As AssemblyDocument = ThisDoc.Document
Dim oAsmDef As AssemblyComponentDefinition = oMainAsm.ComponentDefinition
' get the occurrence by its position in the occurrences collection
Dim oOcc As ComponentOccurrence = oAsmDef.Occurrences.Item(1)
'MsgBox (oOcc.Name)
Dim oDef As PartComponentDefinition = oOcc.Definition
Dim oDoc As PartDocument = oDef.Document
'reference to the CC properties - oProps
Dim oPropSets As PropertySets = oDoc.PropertySets
Dim oProps As PropertySet = oPropSets.Item("Content Library Component Properties")
' family id
Dim oProp As Inventor.Property = oProps.Item("FamilyId")
Dim FamilyId As String = oProp.Value
'MsgBox("FamilyId: " + FamilyId)
'reference to the ContentFamily
Dim oContentCenter As ContentCenter = ThisApplication.ContentCenter
Dim oFamily As ContentFamily = oContentCenter.GetContentObject("v3#" + FamilyId + "#")
'MsgBox("Content Family DisplayName:  " + oFamily.DisplayName & vbNewLine & _
'	    "Rows in Family:  " & oFamily.TableRows.Count ) '"v3#" + FamilyId + "#"
'create new member file
Dim ErrorType As MemberManagerErrorsEnum
Dim strContentPartFileName As String
Dim strErrorMessage As String
Dim oCustomInput As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
'Set the pipe length
oCustomInput.Value("PL")=600
strContentPartFileName = oFamily.CreateMember(NewRow, ErrorType, strErrorMessage, , , ,oCustomInput)
'replace the existing component with the new one
oOcc.Replace(strContentPartFileName, False)
