- Mute
- Permalink
- Report
Ok. I have tangled head.
First I want say that second rule is ok - run. no problem
First rule: I made part- .ipt. I created rectanguler sketch and model. This rule I have tried on rectangle sketch.
when I have open only this part. This rule write error with membernotfound...
Then I have tried the last (third rule) - I made assambly- .iam . I put the part with rectangle sketch. I have tried third rule on sketch of part. No problem. This rule run.
then I have tried made only rectanguler sketch in assambly with part. And first rule I put in the assambly and run!.
Then I found out that when I have open assembly and I open part. - First rule run in part (but condition is that you must have open assembly)
Then I tried closed all files and open only part and first rule wrote error with memeber
So it means I don´t know why, that first rule run in part, when I have open assembly with part.
Do you know why??
Do you understand me what I mean? ![]()
