amarcoc
749 Views, 11 Replies
iLogic - Suppress all features except Features with "DXFn" name
Hi.
I rename features with DXF1, DXF2, DXF3, etc to export DXF faces with only those features active.
Am trying to make a simple iLogic macro to run feature tree and find DXF on each feature (that can be any type), but I cant even access features name.
I want to exclude all features except features with DXF on its name.
Any help?
Thanks!!!
JhoelForshav
in reply to: amarcoc
Hi @amarcoc
Do you simply want to suppress all features within a part without dxf in the name?
For Each oFeature As PartFeature In ThisDoc.Document.ComponentDefinition.Features
	If oFeature.Name.Contains("DXF") = False Then oFeature.Suppressed = True
Next
amarcoc
in reply to: JhoelForshav
Well, you made it look too simple :grinning_face_with_sweat: . But Yes, that's what I need.
Made a small improvement to be case in-sensitive.
	If UCase(oFeature.Name).Contains("DXF") = False Then oFeature.Suppressed = True
Next
Any chance on saving features state before suppressing? To be able to restore original state later.
JhoelForshav
Hi @amarcoc
Regarding saving the state:
I thought I'd use the features attributes to store a simple boolean value in it for it's suppressed state.
For some reason though I couldn't create an attribute with boolean value, so i had to make it a string. I don't know why because I think it should work with ValueTypeEnum.kBooleanType.
Anyways,
this rule stores a string "True"/"False" as an attribute in the feature:
		Dim oAttributeSet As AttributeSet
		Dim oAttribute As Inventor.Attribute
		If oFeature.AttributeSets.NameIsUsed("SuppressedInfo")
			oAttributeSet = oFeature.AttributeSets.Item("SuppressedInfo")
			Try
				oAttribute = oAttributeSet.Item("Suppressed")
				oAttribute.Value = If (oFeature.Suppressed, "True", "False")
			Catch
				If oAttributeSet Is Nothing Then MsgBox("hejhejhej")
				oAttribute = oAttributeSet.Add("Suppressed", ValueTypeEnum.kStringType, If (oFeature.Suppressed, "True", "False"))
			End Try
		Else
			oAttributeSet = oFeature.AttributeSets.Add("SuppressedInfo")
		End If
	End If
Next
Then to restore the features use this rule:
		Try
			Dim oSuppressed As String = oFeature.AttributeSets.Item("SuppressedInfo").Item("Suppressed").Value
			oFeature.Suppressed = If (oSuppressed = "True", True, False)
		Catch
		End Try
	End If
Next
Hope it helps :slightly_smiling_face:
EDIT: I forgot to add your UpperCase improvement. Don't forget to add it to the code again :winking_face:
JhoelForshav
To late to edit the post now, but obviously the line
Should not be there! :grinning_squinting_face: I just forgot to delete it...
amarcoc
Thanks!!!!
That's it. I will work on your code from here.
Thanks!!!
amarcoc
Hi again.
One small issue:
- I run the first code. It will create the attribute set.
- If I suppress or unsuppress some feature, the attributeset will be outdated.
Any way to delete the whole attribute set before checking if the attribute exists?
amarcoc
@JhoelForshav Could you check my last question? Any help? :slightly_smiling_face:
JhoelForshav
Hi @amarcoc
Sorry I missed this question...
I don't really understand what you mean. Could you try to explain further? :slightly_smiling_face:
amarcoc
Please check attached "_TESTE.ipt" file.
You can make a quick test:
- Run your first macro and then run your second macro.
- You will find Hole5 and Hole4 suppressed, even if it wasn't suppressed before.
Under some conditions, the second macro won't restore original suppress state.
JhoelForshav
Hi @amarcoc
Thank you. Now I see the problem.
Try this as the first rule :slightly_smiling_face:
Dim oDoc As PartDocument = ThisDoc.Document
Dim oSuppress As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
For Each oFeature As PartFeature In oDoc.ComponentDefinition.Features
			Try
			Catch
			End Try
		Else
		End If
		If oFeature.Suppressed = False Then oSuppress.Add(oFeature)
	End If
Next
oDoc.ComponentDefinition.SuppressFeatures(oSuppress)
The thing is that because of relationships. Suppressing one feature resulted in another feature being suppressed before the code had the chance to check it. Therefore the attribute was set to suppressed.
amarcoc
Thank you. Understood the problem!
Worked perfect.
