05-15-2020
12:17 PM
- Mute
- Permalink
- Report
05-15-2020
12:17 PM
Hi!
I would like to create a custom RibbonTab. I used your code, but unfortunately it doesn't appear the tab. When I open Inventor it "MyRibbon" appears just for 1 sec then disappear. How can I solve it? Can you help me?
#Region "User interface definition"
' Sub where the user-interface creation is done. This is called when
' the add-in loaded and also if the user interface is reset.
Private Sub AddToUserInterface()
' This is where you'll add code to add buttons to the ribbon.
'** Sample to illustrate creating a button on a new panel of the Tools tab of the Part ribbon
Dim oUIM As UserInterfaceManager = m_IA.UserInterfaceManager
Dim oIFS As InterfaceStyleEnum = oUIM.InterfaceStyle
If oIFS = InterfaceStyleEnum.kRibbonInterface Then
Dim oRibs As Ribbons = oUIM.Ribbons
Dim oAssyRib As Ribbon = oRibs.Item("ZeroDoc")
Dim oAssyRibTabs As RibbonTabs = oAssyRib.RibbonTabs
Dim oAssyRibTab As RibbonTab = oAssyRibTabs.Add("MyRibbon", "id_MyCustomRibbon", m_clientID, "id_TabTools", True)
End IfI'm using Inventor 2020 and VS2017.
