05-13-2020
11:50 PM
- Mute
- Permalink
- Report
05-13-2020
11:50 PM
Hi @jishee
Adding by expression might not always work. The expression could contain a name of a parameter that doesn't exist in the assembly. Either a user parameter that hasn't been copied yet or a model parameter.
My suggestion is to try to use the expression but if it fails, use the parameter value instead:
Dim asmDoc As Inventor.AssemblyDocument = ThisDoc.Document For Each refDoc As Inventor.Document In asmDoc.AllReferencedDocuments Dim refDocUserParams As UserParameters = asmDoc.ComponentDefinition.Parameters.UserParameters 'Look for part documents. If refDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then Dim partDoc As Inventor.PartDocument = refDoc 'Add the part parameters to the assembly. For Each partUserParam As UserParameter In refDoc.ComponentDefinition.Parameters.UserParameters 'Check to see if the parameter already exists. Dim checkParam As UserParameter = Nothing Try checkParam = refDocUserParams.Item(partUserParam.Name) Catch checkParam = Nothing End Try If checkParam Is Nothing Then 'Create the missing parameter. Try refDocUserParams.AddByExpression(partUserParam.Name, partUserParam.Expression, partUserParam.Units) Catch refDocUserParams.AddByValue(partUserParam.Name, partUserParam.Value, partUserParam.Units) End Try Else 'Update the value of the existing parameter. Try checkParam.Expression = partUserParam.Expression Catch checkParam.Value = partUserParam.Value End Try End If Next End If Next
Jhoel Forshav
Download my free Inventor Addin - Hole Projector
LinkedIn | Ideas | Contributions | Blog posts | Website
