05-13-2020
11:27 AM
- Mute
- Permalink
- Report
05-13-2020
11:27 AM
Using iLogic, I want to be able to copy user parameters from part files into an assembly. I found an example that copies user parameters from an assembly into part files and tried modifying it to suit my needs and it runs without errors but does not copy over any of the user parameters. The code I have is below.
Dim asmDoc As Inventor.AssemblyDocument = ThisDoc.Document For Each refDoc As Inventor.Document In asmDoc.AllReferencedDocuments 'Look for part documents. If refDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then Dim partDoc As Inventor.PartDocument = refDoc Dim refDocUserParams As UserParameters = refDoc.ComponentDefinition.Parameters.UserParameters 'Add the part parameters to the assembly. For Each partUserParam As UserParameter In refDoc.ComponentDefinition.Parameters.UserParameters 'Check to see if the parameter already exists. Dim checkParam As UserParameter = Nothing Try checkParam = refDocUserParams.Item(partUserParam.Name) Catch ex As Exception checkParam = Nothing End Try If checkParam Is Nothing Then 'Create the missing parameter. refDocUserParams.AddByExpression(partUserParam.Name, partUserParam.Expression, partUserParam.Units) Else 'Update the value of the existing parameter. checkParam.Expression = partUserParam.Expression End If Next End If Next
Any help with what I am doing wrong is appreciated.
