729 Views, 3 Replies
Performance VBA vs .NET
I am seeing a huge difference in the performance between VBA and .NET.
A code that executes in under a second in VBA takes more than 65 seconds in .NET:thinking_face:
VBA: (<0.5 sec)
 Sub testperformance()
    Dim ElapsedTime As Long:   ElapsedTime = Timer
    Dim oPartDoc As PartDocument: Set oPartDoc = ThisApplication.ActiveDocument
    Dim oPartDef As PartComponentDefinition: Set oPartDef = oPartDoc.ComponentDefinition
    Dim nCylinders As Integer
    Dim oSurfBody As SurfaceBody
    Dim oFace As Face
    For Each oSurfBody In oPartDef.SurfaceBodies
        For Each oFace In oSurfBody.faces
            If oFace.SurfaceType = SurfaceTypeEnum.kCylinderSurface Then
                nCylinders = nCylinders + 1
            End If
        Next
    Next
    MsgBox Timer - ElapsedTime
End Sub
.NET: (> 65 sec)
        Dim ThisApplication As Application = GetObject(, "Inventor.application")
        Dim start_time As DateTime = Now
        Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
        Dim oPartDef As PartComponentDefinition = oPartDoc.ComponentDefinition
        Dim nCylinders As Int16 = 0
        For Each oSurfBody As SurfaceBody In oPartDef.SurfaceBodies
            For Each oFace As Face In oSurfBody.Faces
                    nCylinders += 1
                End If
            Next
        Next
        Dim elapsed_time As TimeSpan = Now.Subtract(start_time)
        MsgBox(elapsed_time.TotalSeconds)
    End Sub
End Class
Code is run on a complex part file with approx 10.000 faces.
