730 Views, 3 Replies
Performance VBA vs .NET
I am seeing a huge difference in the performance between VBA and .NET.
A code that executes in under a second in VBA takes more than 65 seconds in .NET:thinking_face:
VBA: (<0.5 sec)
 Sub testperformance()
    Dim ElapsedTime As Long:   ElapsedTime = Timer
    Dim oPartDoc As PartDocument: Set oPartDoc = ThisApplication.ActiveDocument
    Dim oPartDef As PartComponentDefinition: Set oPartDef = oPartDoc.ComponentDefinition
    Dim nCylinders As Integer
    Dim oSurfBody As SurfaceBody
    Dim oFace As Face
    For Each oSurfBody In oPartDef.SurfaceBodies
        For Each oFace In oSurfBody.faces
            If oFace.SurfaceType = SurfaceTypeEnum.kCylinderSurface Then
                nCylinders = nCylinders + 1
            End If
        Next
    Next
    MsgBox Timer - ElapsedTime
End Sub
.NET: (> 65 sec)
        Dim ThisApplication As Application = GetObject(, "Inventor.application")
        Dim start_time As DateTime = Now
        Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
        Dim oPartDef As PartComponentDefinition = oPartDoc.ComponentDefinition
        Dim nCylinders As Int16 = 0
        For Each oSurfBody As SurfaceBody In oPartDef.SurfaceBodies
            For Each oFace As Face In oSurfBody.Faces
                    nCylinders += 1
                End If
            Next
        Next
        Dim elapsed_time As TimeSpan = Now.Subtract(start_time)
        MsgBox(elapsed_time.TotalSeconds)
    End Sub
End Class
Code is run on a complex part file with approx 10.000 faces.
JelteDeJong
One thing that significantly impacts performance is if your program is running inside Inventor or not. When your program is running within Inventor’s process it’s referred to as in-process. When your program is running in another process it referred to as out-of-process. Add-ins and VBA macros, run in-process. Exe’s and programs that run from within other products all run in a process outside of Inventor.
i expect that your .net code is run out of process. If so try to make a addin and retry it.
this page is a great refrence for performance. (especialy have a look at the chapter Running In-Process vs. Out-of-Process)
Jelte de Jong
Blog: hjalte.nl - github.com
in reply to: JelteDeJong
Yes, I realize that's the issue.
It just easier to debug, but I will move it to an addin.
Thanks.
JelteDeJong
I often use a UnitTest to start and debug addin functions out of process. that makes debugging almost as easy as a standalone application (but it's slow) but for the end users there is the speed of an addin.
Jelte de Jong
