I solved my own problem. The code works as well as it can, for the time being. Unfortunately, Inventor 2019 API currently does not support the application of a hatch pattern to a sketch profile. It only allows for a solid fill to be applied. However, I recently learned that hatching a sketch profile via iLogic was available on the now-closed beta build of Inventor 2021, which mean in future, this code can be improved to apply a real hatch pattern, not a solid fill.
Working code:
'Definitions
Dim oDoc As DrawingDocument
Dim oSht As Sheet
Dim oDV As DrawingView
Dim oSketch As DrawingSketch
Dim oDC As DrawingCurve
'Set a reference to the active document. This assumes it is a drawing document.
oDoc = ThisApplication.ActiveDocument
'Set a reference to the active sheet.
oSht = oDoc.ActiveSheet
'Loop through all views that currently exist on the active sheet
For Each oDV In oSht.DrawingViews
       'Create a new sketch on the active view
	oSketch = oDV.Sketches.Add
	'Put the sketch in edit mode
	oSketch.Edit
	'Set a reference to the transient geometry object
	Dim oTG As TransientGeometry
	oTG = ThisApplication.TransientGeometry
	'Project all edges of the part shown in the view
        For Each oDC In oDV.DrawingCurves
      	     oSketch.AddByProjectingEntity(oDC)
        Next
	'Create a profile from the projected edges
	Dim oProfile1 As Profile
	oProfile1 = oSketch.Profiles.AddForSolid(False, oCollection1)
	'Fill the profile with a SOLID pattern
	Call oSketch.SketchFillRegions.Add(oProfile1)
	''Fill the profile with a HATCH pattern (available only in Inventor 2021)
	'Call oSketch.SketchHatchRegions.Add(oProfile1)
	'Exit the sketch
	oSketch.ExitEdit
Next
