05-05-2020
09:58 PM
- Mute
- Permalink
- Report
05-05-2020
09:58 PM
I worked out the approach for a sketchsymbol using the control definitions as below:
Dim oDoc As DrawingDocument
oDoc = ThisDoc.Document
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
Dim oSketch As SketchedSymbol
For Each oSketch In oSheet.SketchedSymbols
If Left(oSketch.Name, 5) = "Notes" Then
Dim oSketchSketch As Sketch
oSketch.Definition.Edit(oSketchSketch)
NotesText = oSketchSketch.TextBoxes.Item(1)
ThisApplication.CommandManager.DoSelect(NotesText)
Dim cds As ControlDefinitions
cds = ThisApplication.CommandManager.ControlDefinitions
cds.Item(2637).Execute()
' For i = 1 To cds.Count
' If cds.Item(i).DisplayName = "Edit Text" Then
' MsgBox(i)
' cds.Item(i).Execute()
' End If
' Next i
oSketch.Definition.ExitEdit
Else ' Do nothing
End If
Next oSketchThis doesn't seem to work for general notes not inside a sketch... Can anyone explain this to me? Command 'DrawingGeneralNoteEditCtxCmd' does not seems to work?
Dim oSheet As Sheet
Dim oNote As GeneralNote
oNote = oSheet.DrawingNotes.GeneralNotes.Item(1)
ThisApplication.CommandManager.DoSelect(oNote)
cds.Item(1130).Execute()
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
