gcoombridge
467 Views, 1 Reply
Activate the Text Box Dialogue Box (In IDW environment)
Hi All,
I currently have some time on my hands so I'm tweaking my idw templates with everything useful I can think of. I use an ilogic form to enter titleblock values etc... and on this form I also have a few rules that print to PDF with the correct rev and so on. I also wanted one to place and edit drawing notes (I haven't decided between sketch symbols or general notes).
I understand how to place these, edit their components, delete them etc... using code but rather than adjusting the contents of the notes through the .formattedtext approach I would just like to fire up the dialogue box you get when you manually double-click on text in the IDW environment. Is this possible?
The notes I am looking to create might say anything and may have 10 numbered points etc...
This is where I got to with a sketch symbols version (below). It opens the symbol for editing and selects the textbox..
Dim oDoc As DrawingDocument
oDoc = ThisDoc.Document
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
Dim oSketch As SketchedSymbol
For Each oSketch In oSheet.SketchedSymbols
	If Left(oSketch.Name, 5) = "Notes" Then
	Dim oSketchSketch As Sketch
	oSketch.Definition.Edit(oSketchSketch)
	NotesText = oSketchSketch.TextBoxes.Item(1)
	ThisApplication.CommandManager.DoSelect(NotesText)
	oSketch.Definition.ExitEdit
Else ' Do nothing
	End If
Next oSketch
Thanks for your help!
Glenn
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
