Curtis_Waguespack
Hi @Anonymous
Give this a try.
I hope this helps.
Curtis
'this is the name of the symbol library file,
'the path to this location is specified under
'Tools tab > Application Options button > Files tab
oSymbolDrawingName = "Sketched Symbols"
'check file type
If ThisDoc.Document.DocumentType <> kDrawingDocumentObject Then
Return
End If
'define the drawing document
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oSketchSymLib As SketchedSymbolDefinitionLibrary
oSketchSymLib = oDrawDoc.SketchedSymbolDefinitions.SketchedSymbolDefinitionLibraries.Item(oSymbolDrawingName)
Dim oSymbolList As New ArrayList
For Each oSymbolDef In oSketchSymLib.SketchedSymbolDefinitions
	oSymbolList.Add(oSymbolDef.name)
Next
oName = InputListBox("Pick a Symbol",oSymbolList, oSymbolList(0), "iLogic", "List of Symbols")
If oName = "" Then
	Return 'exit rule
End If
Dim oSymDef As SketchedSymbolDefinition
'place the symbol in the Drawing Resources folder
oSymDef = oDrawDoc.SketchedSymbolDefinitions.AddFromLibrary(oSketchSymLib, oName, True)
Dim oPosition As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(10, 15)
'[use this if the symbol has no prompted entry
Dim oSymbol As SketchedSymbol
oSymbol = oDrawDoc.ActiveSheet.SketchedSymbols.Add(oSymDef, oPosition, 0, 1, )
