04-30-2020
08:27 AM
- Mute
- Permalink
- Report
04-30-2020
08:27 AM
Hi @Anonymous ,
If your Tools > application options > Files > Symbol Library path is specifying the server path, then you could use something like this.
I hope this helps.
Curtis
'this is the name of the symbol library file, 'the path to this location is specified under 'Tools tab > Application Options button > Files tab oSymbolDrawingName = "Sketched Symbols" 'This is the name of the symbol to place oSymbolName = "Test101" 'check file type If ThisDoc.Document.DocumentType <> kDrawingDocumentObject Then Return End If 'define the drawing document Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument Dim oSketchSymLib As SketchedSymbolDefinitionLibrary oSketchSymLib = oDrawDoc.SketchedSymbolDefinitions.SketchedSymbolDefinitionLibraries.Item(oSymbolDrawingName) Dim oSymDef As SketchedSymbolDefinition 'place the symbol in the Drawing Resources folder oSymDef = oDrawDoc.SketchedSymbolDefinitions.AddFromLibrary(oSketchSymLib, oSymbolName, True) Dim oPosition As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(10, 15) '[use this if the symbol has no prompted entry Dim oSymbol As SketchedSymbol oSymbol = oDrawDoc.ActiveSheet.SketchedSymbols.Add(oSymDef, oPosition, 0, 1, ) '] ''or ''[ use this if the symbol has prompted entry 'Dim sPromptStrings(2) As String 'string array with 2 items, for two prompts 'sPromptStrings(0) = "Hello" 'sPromptStrings(1) = "World" 'Dim oSymbol As SketchedSymbol 'oSymbol = oDrawDoc.ActiveSheet.SketchedSymbols.Add(oSymDef, oPosition, 0, 1, sPromptStrings)
