328 Views, 2 Replies
Ilogic for changing partno from a excel
I Was looking for a ilogic code which can help in changing some of the part numbers in an assembly as per the excel sheet, For Example : We have an assembly with 35 Components and 5 Sub assemblies  - I need to check the part no's with 1st column in the excel - if exists then i need to change the number to the 2nd Column as per the excel file attached.
