- Mute
- Permalink
- Report
I would like to insert sketch symbol with the name "TAG" into the active drawing using a rule. User will then pick location. This sketch symbol has no prompted entries.
In the other case i would like to insert a sketch symbol with name "REF" into the active drawing but this sketch symbol will have prompted entries. Also with user to pick location.
- Mute
- Permalink
- Report
Hi, Here I share a drawing file in Inventor 2018, in which I have two sketch symbols. The first sketch symbol has four requested entries, the second sketch symbol has no requested entries. There are four ilogic rules, two for each sketch symbol.
One of the rules will place the sketch symbol in a position determined by coordinates.
The second rule will place the sketch symbol with the mouse.
Note that the sketch symbol with 4 entries has the sproptstring defined in (3) that is because it counts from zero.
I hope this helps. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
- Mute
- Permalink
- Report
Thank you for this, this could work. Is there a way to have the sketch symbol preview so the user has an idea of where it will be placed? The preview would work the same as inserting a sketch symbol through double clicking thorugh the the tree.
- Mute
- Permalink
- Report
Adding to the above, ideally it would be great have the ability to snap to existing geometry using the insertion insertion point grip.
Thanks again.
- Mute
- Permalink
- Report
Hello, I was also wondering if it is possible to control/toggle the symbol library options within the code.
Main goal is I have some sketch symbols that would require a leader and others that don't.
Symbol library options:
Symbol Clipping
Static
Leader
Visible options
- Mute
- Permalink
- Report
Has anyone found a way to get the inserting symbol snap to a grip on an existing symbol? I am wanting to use this for some notes that we place on the drawing and stack them on top of the title block.
Thank you in advance.
- Mute
- Permalink
- Report
Thanks for the Sample Code. Can we control the sketch selection via excel linked parameter. For example if I want to replace certain sketch based on selection made in Excel sheet linked with Inventor Model.
- Mute
- Permalink
- Report
Hi everyone, is it technically possible to create a rule that would insert symbols from a library that is located on a server?
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Hi @Anonymous ,
If your Tools > application options > Files > Symbol Library path is specifying the server path, then you could use something like this.
I hope this helps.
Curtis
'this is the name of the symbol library file, 'the path to this location is specified under 'Tools tab > Application Options button > Files tab oSymbolDrawingName = "Sketched Symbols" 'This is the name of the symbol to place oSymbolName = "Test101" 'check file type If ThisDoc.Document.DocumentType <> kDrawingDocumentObject Then Return End If 'define the drawing document Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument Dim oSketchSymLib As SketchedSymbolDefinitionLibrary oSketchSymLib = oDrawDoc.SketchedSymbolDefinitions.SketchedSymbolDefinitionLibraries.Item(oSymbolDrawingName) Dim oSymDef As SketchedSymbolDefinition 'place the symbol in the Drawing Resources folder oSymDef = oDrawDoc.SketchedSymbolDefinitions.AddFromLibrary(oSketchSymLib, oSymbolName, True) Dim oPosition As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(10, 15) '[use this if the symbol has no prompted entry Dim oSymbol As SketchedSymbol oSymbol = oDrawDoc.ActiveSheet.SketchedSymbols.Add(oSymDef, oPosition, 0, 1, ) '] ''or ''[ use this if the symbol has prompted entry 'Dim sPromptStrings(2) As String 'string array with 2 items, for two prompts 'sPromptStrings(0) = "Hello" 'sPromptStrings(1) = "World" 'Dim oSymbol As SketchedSymbol 'oSymbol = oDrawDoc.ActiveSheet.SketchedSymbols.Add(oSymDef, oPosition, 0, 1, sPromptStrings)
- Mute
- Permalink
- Report
Hi, thank you. It works great. And I have one more question. Our library contains more items. It is possible for a dialogue to appear at the beginning and to be able to choose what I need.
- Mute
- Permalink
- Report
Hi @Anonymous
Give this a try.
I hope this helps.
Curtis
'this is the name of the symbol library file, 'the path to this location is specified under 'Tools tab > Application Options button > Files tab oSymbolDrawingName = "Sketched Symbols" 'check file type If ThisDoc.Document.DocumentType <> kDrawingDocumentObject Then Return End If 'define the drawing document Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument Dim oSketchSymLib As SketchedSymbolDefinitionLibrary oSketchSymLib = oDrawDoc.SketchedSymbolDefinitions.SketchedSymbolDefinitionLibraries.Item(oSymbolDrawingName) Dim oSymbolList As New ArrayList For Each oSymbolDef In oSketchSymLib.SketchedSymbolDefinitions oSymbolList.Add(oSymbolDef.name) Next oName = InputListBox("Pick a Symbol",oSymbolList, oSymbolList(0), "iLogic", "List of Symbols") If oName = "" Then Return 'exit rule End If Dim oSymDef As SketchedSymbolDefinition 'place the symbol in the Drawing Resources folder oSymDef = oDrawDoc.SketchedSymbolDefinitions.AddFromLibrary(oSketchSymLib, oName, True) Dim oPosition As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(10, 15) '[use this if the symbol has no prompted entry Dim oSymbol As SketchedSymbol oSymbol = oDrawDoc.ActiveSheet.SketchedSymbols.Add(oSymDef, oPosition, 0, 1, ) ']
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Works great, just wondering if there's a way to force on the static option?
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Hi, i am looking for the exact case, where a preview would be ideal. Do you have a code that works for this?
