1130 Views, 10 Replies
How do delete the Angle Constraint of Selected Components in Assembly ILogic
I want to delete the Angle Constraint of Components which are selecting by me.
I have tried below Loop code but it showing attached error. Can you please help me to find the error in this code.
Dim oAsm As AssemblyDocument = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition = oAsm.ComponentDefinition
Line1 :
comp = ThisApplication.CommandManager.Pick(
SelectionFilterEnum.kAssemblyOccurrenceFilter,
"Select a components")
AngleConstraint.Delete(comp)
GoTo Line1
Thanks & Regards,
Manoj Sampath
Yijiang.Cai
Please try the code sample below in the iLogic rule -
oAsm = ThisApplication.ActiveDocument
oAsmCompDef = oAsm.ComponentDefinition
Line1:
Dim oComp As ComponentOccurrence
oComp = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select a components")
Dim oCons As AssemblyConstraint
For Each oCons In oComp.Constraints
    If oCons.Type = kAngleConstraintObject Or oCons.Type = kAngleConstraintProxyObject Then
        oCons.Delete
    End If
Next
GoTo Line1
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
in reply to: Yijiang.Cai
@Yijiang.Cai
Thanks for your reply,
I have faced attached error while select the components. Can you please check and give your suggestion.
Thanks & Regards,
Manoj Sampath
Yijiang.Cai
Please use the updated one, and it should be fixed. If it works for you, please accept it as solution.
Line1 :
If oComp Is Nothing Then
	Exit Sub
End If
        oCons.Delete
    End If
Next
GoTo Line1
River Cai
Autodesk, Inc.
@Yijiang.Cai
Now the error message is not coming, But the Angle constraint not get delete.
I'm working on the Code you have suggested, Please update me if you get solution for this.
Thanks & Regards,
Manoj Sampath
Yijiang.Cai
Sorry for my typo when copying the code sample in the second reply from me, and I have updated it. Please copy the code sample in my second reply, and have a try.
River Cai
Autodesk, Inc.
@Yijiang.Cai
I have used below Code, Is this the one you mention?
Angle constraints not deleting by this code.
Thanks  & Regards,\
Manoj Sampath
Yijiang.Cai
Could you copy and paste the code sample you use here?
River Cai
Autodesk, Inc.
@Yijiang.Cai
Sorry. Below is the code
Line1 :
Exit Sub
End If
oCons.Delete
End If
Next
GoTo Line1
Yijiang.Cai
It works for me when using the code sample. What release of Inventor you are using now?
Line1 :
Exit Sub
End If
If oCons.Type = Inventor.ObjectTypeEnum.kAngleConstraintObject Or oCons.Type = Inventor.ObjectTypeEnum.kAngleConstraintProxyObject Then
oCons.Delete
End If
Next
GoTo Line1
River Cai
Autodesk, Inc.
@Yijiang.Cai
This Code Working for me Now. Thanks for your help.
Thanks & Regards,
Manoj Sampath
