johnsonshiue
Hi! I believe it is indeed doable using iLogic. I have seen rules capable of creating drawing views and some annotations automatically.
Another option is to use Sheet Format. Start up a drawing and go to browser -> Sheet Format -> pick one fitting your need -> select a model file. It will help create drawing views quickly. You can also define your own sheet format by opening up an existing idw/dwg -> Sheet Format -> Create Sheet Format.
Many thanks!
Software Test Engineer
