AdamAG99T
in reply to: kkruegerWZZH4
If you're using this for multiple users then yes you could save it as a regular rule on the assembly template. The main benefit of using an external rule would be to make it easier to add to previously made documents, since you would just need to add the trigger instead of creating a new rule in each document as well as the trigger.
