Hi @kristianhric
this can be done with an iLogic rule, but did you know that you can do this from the BOM editor?
If you add the custom iproperty to the BOM you can then "fill" the value or copy/paste the value into each cell in the column, and the custom iproperty will be automatically created in the component files, and set the cell value.
I'll post an ilogic example in a bit to do this too, but sometimes using the built in abilities is the better approach.... and of course it's just nice to know its there.
I hope this helps.
Curtis
