- Mute
- Permalink
- Report
Hello everyone,
I am fairly new to I Logic and am looking to export a custom I Property column from the BOM menu in an assembly (labeled Finish) into each part, and create a custom property there Labeled finish. I have found one similar that does quantity so i was wondering of i can do that with finishes this way i can update any finish in the BOM instead of opening each part individually.
Thank you
- Mute
- Permalink
- Report
this can be done with an iLogic rule, but did you know that you can do this from the BOM editor?
If you add the custom iproperty to the BOM you can then "fill" the value or copy/paste the value into each cell in the column, and the custom iproperty will be automatically created in the component files, and set the cell value.
I'll post an ilogic example in a bit to do this too, but sometimes using the built in abilities is the better approach.... and of course it's just nice to know its there.
I hope this helps.
Curtis
- Mute
- Permalink
- Report
Here is a quick example, (welcome to the forum, btw)
Try
oFinish = iProperties.Value("Custom", "Finish")
Catch
'property not found
Return' exit rule
End Try
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAssyDoc.ComponentDefinition
If oAsmCompDef.Type = ObjectTypeEnum.kWeldmentComponentDefinitionObject Then
Return 'exit rule
End If
Dim oOcc As ComponentOccurrence
Dim oDoc As Document
For Each oOcc In oAsmCompDef.Occurrences.AllLeafOccurrences
oDoc = oOcc.Definition.Document
oPropSet = oDoc.PropertySets.Item("User Defined Properties")
Try
oProp = oPropSet.Add("", "Finish")
Catch
oProp = oPropSet.Item("Finish")
End Try
oProp.value = oFinish
Next
- Mute
- Permalink
- Report
