Sergio.D.Suárez
Hi, Your rule has not given me problems.
Only I have to tell you some things, I have added some lines to activate or deactivate the thread, if it is not in the defined ranges. Because otherwise I would give error.
Feature.IsActive("Thread1")= True
If dia = 0.5 in     Then
Feature.ThreadDesignation("Thread1") = "1/2-13 UNC"
Else If dia = 0.625 in  Then
	MessageBox.Show("Message", "Title")
Feature.ThreadDesignation("Thread1") = "5/8-11 UNC"
Else If dia = 0.75 in Then
Feature.ThreadDesignation("Thread1") = "3/4-10 UNC"
Else If dia = 0.875 in Then
Feature.ThreadDesignation("Thread1") = "7/8-9 UNC"
Else If dia = 1 in Then
Feature.ThreadDesignation("Thread1") = "1-8 UNC"
Else
	Feature.IsActive("Thread1")= False
End If
On the other hand, understand the difference with ipart and make an ilogic component, if you need many instances of the different measures component, with ilogic you cannot do it with the same part. You will need to copy the file with a new name and configure this new file for your need. If you face this case, a ipart would be a better solution.
I hope I have been clear, and this can help with your problem. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
