Sergio.D.Suárez
Hi, This code could be useful to you, at least it does not throw me errors. I retouch it a bit to simplify it.
Dim templateFile As String 'Create a drawing from the drawing template
templateFile = "C:\VaultWorkingFolder\Designs\Templates\SilencerAssembly.idw" '''Place the path of your template idw
Dim ViewScale As Double = 3 / 16
dwgQuery = MsgBox("Would you like to Create a drawing for this MODEL?", vbYesNo, "Drawing Selection")
If dwgQuery=vbYes
	Dim oDoc As Document = ThisDoc.Document  ' Part Document or Assembly Document
	Dim oDrawingDoc As DrawingDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject,templateFile,True)
	oDrawingDoc.Activate()
	Dim oSheet As Sheet = oDrawingDoc.Sheets.Item(1)
	Dim oPoint1 As Point2d=ThisApplication.TransientGeometry.CreatePoint2d(1, 1)
	Dim oPoint2 As Point2d=ThisApplication.TransientGeometry.CreatePoint2d(1, 6)
	Dim oPoint3 As Point2d=ThisApplication.TransientGeometry.CreatePoint2d(5, 1)
	Dim oBaseView As DrawingView =oSheet.DrawingViews.AddBaseView(oDoc,oPoint1,ViewScale,ViewOrientationTypeEnum.kFrontViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
	Dim oView2 As DrawingView =oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint2, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle,ViewScale)
	Dim oView3 As DrawingView =oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint3, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle,ViewScale)
End If
 The idea that you propose is good, you could load all these fragments as subroutines sub - end sub and command them from a main sub main.
That's why I'll add a code below to place dimensions in the drawing views.
Sub main()
If oDoc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject  Then
	Dim oSheet As Sheet
	oSheet = oDoc.ActiveSheet
	Dim oViews As DrawingViews
	Dim oView As DrawingView
	Line1 :
	oView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select view")
	If oView Is Nothing Then Exit Sub
	Dim oGeneralDimensionsEnum As GeneralDimensionsEnumerator
	oGeneralDimensionsEnum = oSheet.DrawingDimensions.GeneralDimensions.Retrieve(oView)
	GoTo Line1
	centrar_Cotas
Else
	MessageBox.Show("Please, open a drawing file", "Retrieve dimensions")
End If
End Sub
Sub centrar_Cotas
	Dim oDoc As DrawingDocument = ThisDoc.Document
	' Set a reference to the active sheet
	Dim oSheet As Sheet = oDoc.ActiveSheet
	' Iterate over all dimensions in the drawing and
	' center them if they are linear or angular.
	For Each oDrawingDim As DrawingDimension In oSheet.DrawingDimensions
	    If TypeOf oDrawingDim Is LinearGeneralDimension Or _
	       TypeOf oDrawingDim Is AngularGeneralDimension Then
	        Call oDrawingDim.CenterText
	    End If
	Next
End Sub
This is a difficult issue, what this code does is to retrieve the dimensions of the drawing, something very useful when the workflow is directed thinking about how the part will be represented in a drawing.
With the code you select the views of the sheet where you need to retrieve the dimensions
I hope some of this help. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
