Sergio.D.Suárez
in reply to: gconley
Hi, a recommendation when working with ilogic is that even when it is not necessary to define the variables, put the variable type and define it correctly. This is a classic type of error that happens due to lack of definition of values.
Here are two methods of how I would try to solve the problem.
dim customPropertySet as inventor.PropertySet= ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Dim dtDate As Date = Now
Dim iprop(2) As String
iprop(1) = "Released for Construction"
iprop(2) = "Released for Review"
Try
  prop = customPropertySet.Item(iprop(1))
Catch
  customPropertySet.Add(dtDate, iprop(1))
End Try
Try
  prop = customPropertySet.Item(iprop(2))
Catch
  customPropertySet.Add(dtDate, iprop(2))
End Try
Here is a simpler method when working on the active document using ilogic shortcuts
iProperties.Value("Custom", iprop(1)) = Now
iProperties.Value("Custom", iprop(2)) = Now
Hope this helps with your problem. Cheers!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
