12-06-2019
07:14 AM
- Mute
- Permalink
- Report
12-06-2019
07:14 AM
I have encountered another issue, the current iteration of the code can't recognize sub assemblies.
I have found a way to get the sub assembly occurrence names, but it does not allow me to create virtual parts with those names.
Is there a better way to do this that will allow for virtual parts to be created for the sub assembly components, or is it better to just have the rule run in each assembly?
'define sComponent & sVirtPart and the rest
'of this code should work as written
' Defines list of Parts
'Dim PartNum As Intager
'PartNum = 1
'Defines a list of parts rule looks through to see if they exist
Dim MyArrayList As New ArrayList
MyArrayList.Add("Lid")
MyArrayList.Add("Module")
Dim VirtList As New ArrayList
VirtList.Add("Bolt")
VirtList.Add("Nut")
VirtList.Add("Washer")
VirtList.Add("Gasket")
'Prepares to turn the Parts list into a string
Dim oString2 As String
j = 0
For Each oString2 In VirtList
VPart = VirtList.Item(j)
' MessageBox.Show(VPart)
j += 1
Dim oString As String
i = 0
Dim iQTY As Integer
iQTY = 0
'Iterates through Parts list to
For Each oString In MyArrayList
Part = MyArrayList.Item(i)
' MessageBox.Show(Part, "Part")
i += 1
'define assembly component to count
Dim sComponent As String
sComponent = Part & ":"
'define virtual component to create
Dim sVirtPart As String
sVirtPart = VPart
'count chars in sComponent
Dim oCnt As Integer = 0
For Each c As Char In sComponent
oCnt += 1
Next
'count chars in sVirtPart
Dim oCnt2 As Integer = 0
For Each c As Char In sVirtPart
oCnt2 += 1
Next
'MessageBox.Show(Part & VirtPart & oCnt & oCnt2)
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAssyDoc.ComponentDefinition
Dim oOccs As ComponentOccurrencesEnumerator
oOccs = oAsmCompDef.Occurrences.AllLeafOccurrences
' Dim oSubOccs As ComponentOccurrences
' oSubOccs = oAssyDoc.ComponentDefinition.Occurrences
For Each oOcc In oOccs
MessageBox.Show(oOcc.Name) 'check line for debugging
'Trace.WriteLine(oOcc.Name, "iLogic") 'debug
If Not oOcc.Suppressed Then
If Left(oOcc.Name, oCnt) = sComponent Then
iQTY += 1 'count the components
End If
' MessageBox.Show("Done0", "Checker")
'look at only virtual components
If TypeOf oOcc.Definition Is VirtualComponentDefinition Then
'find and delete existing virtual parts by name
If Left(oOcc.Name, oCnt2 + 1) = sVirtPart & ":" Then
'delete existing virtual parts if name matches
oOcc.delete
End If
End If
' MessageBox.Show("Done1", "Checker")
End If
Next
Dim identity As Matrix
identity = ThisApplication.TransientGeometry.CreateMatrix()
'create first instance of the virtual part
Dim virtOcc As ComponentOccurrence
virtOcc = oOccs.AddVirtual(sVirtPart, identity)
'add next instance starting at instance2 (if applicable)
Dim index As Integer
If VPart = "Bolt"
QTY = iQTY
Else If VPart = "Nut"
QTY = iQTY * 2
Else If VPart = "Washer"
QTY = iQTY * 3
Else If VPart = "Gasket"
QTY = iQTY
End If
index = 2
Do While index <= QTY
oOccs.AddByComponentDefinition(virtOcc.Definition, identity)
index += 1
Loop
Next
Next
