- Mute
- Permalink
- Report
Hi All,
I have a rule that a looks through each component in an assembly and counts the occurrences of a specified part, to allow for virtual parts to be generated for nut bolts and such.
The rule errors out when it encounters a suppressed component, is there a way to check if components are suppressed and skip those components.
Any suggestions would be appreciated
'iterate through all Of the occurrences in the Assembly
For Each oOcc In oOccs
MessageBox.Show(oOcc.Name)
'Trace.WriteLine(oOcc.Name, "iLogic") 'debug
If Left(oOcc.Name, oCnt) = sComponent Then
iQTY += 1 'count the components
End If
'look at only virtual components
If TypeOf oOcc.Definition Is VirtualComponentDefinition Then
'find and delete existing virtual parts by name
If Left(oOcc.Name,oCnt2 +1) = sVirtPart & ":" Then
'delete existing virtual parts if name matches
oOcc.delete
End If
End If
Next
- Mute
- Permalink
- Report
Hi, without the complete rule and an example model, it is difficult to try to understand what you need to achieve. To start, I would try to place the "on error resume next" instruction below the line
to skip the occurrence that returns error. Cheers
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
- Mute
- Permalink
- Report
Hi Sergio,
Here is the Full code.
I created a dummy assembly as a test file as I can't send out the real one, but it should function in the same way.
The code is currently looking for any component named "Lid", and if it finds any it creates a virtual part "Bolt".
The problem is that if any components in the assembly are suppressed the code errors out. I don't have a way to eliminate suppressions from the assembly I am trying to implement this code in.
So I'm looking for a way to get this to ideally ignore suppressed parts as I wouldn't want a virtual part created if the part was suppressed.
'define sComponent & sVirtPart and the rest
'of this code should work as written
'define assembly component to count
Dim sComponent As String
sComponent = "Lid" & ":"
'define virtual component to create
Dim sVirtPart As String
sVirtPart = "Bolt"
'count chars in sComponent
Dim oCnt As Integer = 0
For Each c As Char In sComponent
oCnt += 1
Next
'count chars in sVirtPart
Dim oCnt2 As Integer = 0
For Each c As Char In sVirtPart
oCnt2 += 1
Next
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAssyDoc.ComponentDefinition
Dim oOccs As ComponentOccurrences
oOccs = oAssyDoc.ComponentDefinition.Occurrences
Dim iQTY As Integer
iQTY = 0
'MessageBox.Show(oOcc.Name) 'check line for debugging
End If
oOcc.delete
End If
End If
Next
Dim identity As Matrix
identity = ThisApplication.TransientGeometry.CreateMatrix()
'create first instance of the virtual part
Dim virtOcc As ComponentOccurrence
virtOcc = oOccs.AddVirtual(sVirtPart, identity)
'add next instance starting at instance2 (if applicable)
Dim index As Integer
index = 2
Do While index <= iQTY
oOccs.AddByComponentDefinition(virtOcc.Definition, identity)
index += 1
Loop
- Mute
- Permalink
- Report
If Not oOcc.Suppressed Then
End If
MessageBox.Show("Done0", "Checker")
oOcc.delete
End If
End If
MessageBox.Show("Done1", "Checker")
End If
Next
- Mute
- Permalink
- Report
I have encountered another issue, the current iteration of the code can't recognize sub assemblies.
I have found a way to get the sub assembly occurrence names, but it does not allow me to create virtual parts with those names.
Is there a better way to do this that will allow for virtual parts to be created for the sub assembly components, or is it better to just have the rule run in each assembly?
' Defines list of Parts
'Dim PartNum As Intager
'PartNum = 1
'Defines a list of parts rule looks through to see if they exist
Dim MyArrayList As New ArrayList
MyArrayList.Add("Lid")
MyArrayList.Add("Module")
Dim VirtList As New ArrayList
VirtList.Add("Bolt")
VirtList.Add("Nut")
VirtList.Add("Washer")
VirtList.Add("Gasket")
'Prepares to turn the Parts list into a string
Dim oString2 As String
j = 0
For Each oString2 In VirtList
VPart = VirtList.Item(j)
' MessageBox.Show(VPart)
j += 1
Dim oString As String
i = 0
Dim iQTY As Integer
iQTY = 0
'Iterates through Parts list to
For Each oString In MyArrayList
Part = MyArrayList.Item(i)
' MessageBox.Show(Part, "Part")
i += 1
sComponent = Part & ":"
sVirtPart = VPart
oCnt += 1
Next
oCnt2 += 1
Next
'MessageBox.Show(Part & VirtPart & oCnt & oCnt2)
Dim oOccs As ComponentOccurrencesEnumerator
oOccs = oAsmCompDef.Occurrences.AllLeafOccurrences
' Dim oSubOccs As ComponentOccurrences
' oSubOccs = oAssyDoc.ComponentDefinition.Occurrences
End If
' MessageBox.Show("Done0", "Checker")
If Left(oOcc.Name, oCnt2 + 1) = sVirtPart & ":" Then
oOcc.delete
End If
End If
' MessageBox.Show("Done1", "Checker")
End If
Next
If VPart = "Bolt"
QTY = iQTY
Else If VPart = "Nut"
QTY = iQTY * 2
Else If VPart = "Washer"
QTY = iQTY * 3
Else If VPart = "Gasket"
QTY = iQTY
End If
index = 2
Do While index <= QTY
index += 1
Loop
Next
Next
