@philip1009 wrote:
  If you want to use iLogic to control your top level assembly it cannot be an iAssembly....
@philip1009
I'm not sure this is technically true, but in practice it should not be an iAssembly, and conversely I would not generally advise using iLogic in an iAssembly... it's a bit like creating an 8 cylinder engine with four steam cylinders and four internal combustion....  could it work? I guess, but I wouldn't want to maintain it.
I think the final solution is going to be iLogic, and I think with some diligent component naming, the code can be pretty tidy, but using a "For each component, if name contains ________" type block...
so with all of that in mind, and since the discussion has been posted over here too, i think that's the better place to continue the conversation:
https://forums.autodesk.com/t5/inventor-customization/using-ilogic-to-enable-or-disable-hardware-in-...
