Curtis_Waguespack
@Anonymous wrote:
When I run the rule the parts disappear, but they do not exclude. When I rebuild the model they reappear. So it is trying to work but not quite there.
 Hi @Anonymous
I feel like you didn't read or didn't understand my last message.
There is nothing in the ilogic tools to help you configure the ipart/iassembly table. There are some iLogic ipart/iassembly functions that will allow you to change from one member to another once you have the tables configured, but that is it.
Think of the ipart/iassembly tables as a library.... ilogic will allow you to trade one book from the library for another, but it does not help you write the books (or build the library).
But you can create a configuration that does not include iparts and iassemblies and make them active/not active quite easily... but then you might not really even need iparts/iassemblies.
In any case, if you're going to go the iLogic route, it'd be best to post to the Inventor Customization forum where programming related questions are better suited:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
