Curtis_Waguespack
Hi @Anonymous
edit: I see where philip1009 stated what I just typed after I replied, but I wanted to make sure this was clear, as your other thread suggested this might not be clear
If I'm not mistaken the ilogic tools for iParts and iAssemblies are just used for changing rows in a iPart or iAssembly component.... so for instance if I had a General arrangement assembly that included iParts and iAssemblies, I could have some iLogic in that assembly that would automate the the "Row Change" of those components based on other selections, etc.
So to state it another way, there is not really anything in the iLogic tools to help you author the iPart/iAssembly factory tables. The iLogic tools simply automate the changing of the iPart/iAssembly members in another assembly.
I hope this helps.
Curtis
