- Mute
- Permalink
- Report
I have an iAssembly that will have many different configurations.
10 Transformers in an iAssembly with table
2 Rectifier configurations in an iAssembly with table
3 UI options (3 more coming)
4 Output Configurations (12 more coming)
I will quit if I have to update 700 models every time a change is made. I started using iAssembly configurations to assist with this. I would like to clean up the table entries and remove all of the screws from the table. How do I use iLogic to include or exclude parts based on the selection of an iAssembly
Example,
I choose rectifier A in the table, I want the extra hardware associated with rectifier B to automatically disable so it is not in the model or the BOM. This will allow the final assembly table to be nice and clean with clear choices for quickly making a new configuration. The hardware has no ability to group in the table so with hundreds of screws in the list, I have no idea what screw I am actually turning off if I have to do it manually.
