in reply to: johnsonshiue
I'm sorry for the slow response. Due to in NDA between my employer and the customer I can't share anything, as everything little detail is property of the customer.
But i found out the issue, but no stable fix for it. I will try to explain it textual as best as possible. It turned out as a representation issue when I reconfigure the main assembly through an iLogic form.
There are two representations defined; 1. Master (which is locked) and 2. Default (the one it should be). Somehow some (not all) subassemblies switch from default to master in this case. When I manually switch them to default everything is correct.
Is there a way to always force the default representation?
