440 Views, 1 Reply
Constraints limits in ilogic
Hi there,
we want to create a chain with a undefined length with ilogic-code. We already got it working to the point, where we can define the count of the parts, the correct number of the parts are copied and arranged to the constraint we used. But we need to change the limits of the constraint in the browser so the chain can move in an angle.
We used the code Constraints.AddAngle but cant figure out how to change the limits.
Is there a code we can use to change the limits or a possibility to change the limits within the used code?
Im sorry for my bad english, but it's not my native language.
mcgyvr
Your English was excellent...
I Think this should get you what you need and ironically is also about a chain..
https://forums.autodesk.com/t5/inventor-customization/create-constraints-using-ilogic-amp-set-limits...
