There are no "simple" instructions for what you just asked. In fact it is one of the things that are often asked, and I tried to create a code as simple as possible to achieve that and shared it.
Why are there no simple instructions? because the ilogic language is based on object language based on VB.net, and each object that provides each given access must be identified.
Ilogic has "shortcuts" of the accesses to access certain properties of a file, but not all the properties and all the different and complex accesses have ilogic shortcuts.
I think you should familiarize yourself with the inventor API, it's a lot of material, but even today I consult it daily.
The question you should have asked would be:
How to learn programming? or where to consult bibliography to learn programming in inventor?
Check any material related to programming in VBA, ilogic, VB.net, there is a lot of material on the internet.
Place doubts about codes you experience in the customization threads
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
