437 Views, 2 Replies
10-30-2019
06:00 PM
- Mute
- Permalink
- Report
10-30-2019
06:00 PM
Greetings all,
I am in the process of setting up an export rule in ilogic and have followed the following:
This method works great however is there a way to define the config file?
I am assuming that it is somewhere in this string:
oDataMedium.FileName = oFolder & "\" & CustomName & " " & oFileName & ".dxf" Dim oCompDef As SheetMetalComponentDefinition oCompDef = oDrawDoc.ComponentDefinition If oCompDef.HasFlatPattern = False Then oCompDef.Unfold Else oCompDef.FlatPattern.Edit End If Dim sOut As String sOut = "FLAT PATTERN DXF?AcadVersion=2010&OuterProfileLayer=OUT PRO" oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName) oCompDef.FlatPattern.ExitEdit Catch End Try
We use dxf's for lasercutting and would like to be able to bulk export sheetmetal flat patterns without any fold lines or etch markings, just inner profile and outer profile
thanks in advance
