09-26-2017
06:34 AM
- Mute
- Permalink
- Report
09-26-2017
06:34 AM
I had this iLogic rule which when ran would export a PDF of the current .idw. We just upgraded to 2018 and it no longer works. I can find no errors with the code as to why it will no longer fire.
When I run it I get two pop ups...
Pop up one:
Pop up two:
I hit ok to both pop ups and nothing ends up happening.
Can someone else try to run it in 2018 and tell me what results or solutions you're able to find?
Thanks!
SyntaxEditor Code Snippet
Sub Main() Dim oDoc As Document Dim oPDFAddIn As TranslatorAddIn Try Dim ThisApp = ThisApplication Dim TransObj As TransientObjects = ThisApp.TransientObjects oDoc = ThisDoc.Document If oDoc.DocumentType <> 12292 Then '12292 = kDrawingDocument object MessageBox.Show("This Rule must be run from within a Drawing Document.", "Incorrect Document Type") Exit Sub End If oPDFAddIn = ThisApp.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oContext = TransObj.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = TransObj.CreateNameValueMap oDataMedium = TransObj.CreateDataMedium If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 0 ' 0 = False, 1 = True oOptions.Value("Remove_Line_Weights") = 1 ' 0 = False, 1 = True oOptions.Value("Vector_Resolution") = 400 ' DPI oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 End If 'Set the PDF target file name oDataMedium.FileName = ThisDoc.Path & "\" & ThisDoc.FileName(False) & ".pdf" Catch MessageBox.Show("Error Getting Document Information" & vbCr & "Is the current Document Saved?", "Document Error") End Try 'Publish document Try oPDFAddIn.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium) Catch MessageBox.Show("Unable to Save PDF" & vbCr & "Is the file open or read only?", "Error Saving Document") End Try End Sub
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
Aaron Schlaack
