johnsonshiue
Hi Peter,
I don't think this is a good practice. Sheet Metal Materials and Thickness should be managed by Sheet Metal Rules. Changing Thickness parameter or Material style outside of Sheet Metal Rules will only add confusion. It is a shortcut. But, it is not the right way to do it. You should create Sheet Metal Rules for all permutation of material style and thickness. Then you can use iLogic rule to activate one of them.
Many thanks!
Software Test Engineer
