326 Views, 1 Reply
Did i forget a setting? i keep struggling with extrution of a section
Has this always been buggy? i wish to cut out the upper part and it keeps highlighting the entire part.
This comes up a lot for me. I works barely if i make a gap at the top but often i do not want that. This is a simplified example.
FINET_Laurent
When you are projecting geometry try and make those lines (they show up green in my case) as construction lines.
This might help.
Best regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
