- Mute
- Permalink
- Report
Hi! I don't believe there is a workflow to replace sketch blocks. If there was no manual workflow, more than likely the iLogic code would not exist. Also, iPart is designed to generate library parts for reuse purpose.
Forget about sketch block for a second. If I understood your request correctly, you would like to drive the sketch text using iLogic, right? There is a workflow you may consider. Text parameters are not supported on iPart author table. But, iProperty is allowed. Here is what you can do.
1) Create a custom iProperty called "Alphabet."
2) Add "Alphabet" as a column on the iPart table.
3) For each member row, enter the desirable letter.
4) Create an iLogic rule assigning this custom property to a pre-defined text parameter. Enable property change/parameter change trigger.
5) In the text sketch, reference the text parameter.
6) Generate the members.
Please try it out and see if it works for you.
Many thanks!
Software Test Engineer
