2062 Views, 7 Replies
Replacing a Sketch Block using iLogic and iPart Parameters
Is there a way to use iLogic to replace a block used in a sketch so that each block corresponds with a different part via iPart?
I know my phrasing of my question is poor so here is an example of what I am looking for:
I have 26 cubes for each of the 26 letters in the alphabet. Each of the cubes are the same exact dimensions but the only change is that each cube has a different letter. I have created each letter as a sketch block which will be extruded from the front top face (the font that I tried to use had issues with the emboss feature so I had to recreate the letters myself). To make things easier, I am using iParts to streamline my designing. Is there a way to define a parameter using iParts or iLogic so that say the sketch block with letter A is used with cube 1, the block with letter B used with cube 2 and so on?
Thank you to anyone who is able to provide assistance,
Zach
