- Mute
- Permalink
- Report
I put together an example. It is greatly simplified, but it should convey the issue. No pun intended.
The example is attached and here is a link to a screencast that displays it in action.
To summarize:
Basically I have a one or two rows of buckets configuration.
In reality the buckets need to follow a path so in the example I set it up the same.
For a one row configuration the second row qty is set to one, BOM structure changed to reference, and the visibility is turned off.
For a two row configuration the required quantity is set, BOM structure is changed to default, and the visibility is turned back on.
The issue is presented when the second row is activated.
The BOM structure of the first bucket element is changed to default via ilogic. The problems is by then the other elements of the pattern have been patterned based on the initial reference BOM Structure of the first element.
This is the reason I need to change the BOM structure for all the elements.
In my example there is a form in the Belt.ipt to configure the holes, select one of the two options.
In the assembly there is a form that will present one of two rules:
Set bucket - Sets the bucket visibility and was intended to set the bom structure.
BOM Structure fix - This is the rule you supplied displaying the error.
Inventor Pro 2023
Vault Pro 2023
