DewayneH
1012 Views, 6 Replies
BOM Structure - Component Pattern Elements
I need to set the BOMStructure of all the elements of a component pattern to reference or default depending on a parameter.
Initially, I thought it would be as easy as setting the BOMStructure for the pattern:
If Parameter("Belt", "BucketRowQ") = 1 Then
Component.InventorComponent("Double-Buckets and Hardware").BOMStructure = BOMStructureEnum.kReferenceBOMStructure
Apparently that does nothing.
Based on my digging, it looks like I have to deal with each element individually.
The quantities are changing so I need to be able to affect all the elements in the pattern regardless of the quantity.
Basically if the parameter = 1, the BOMStructure of all elements will be reference.
If it = 2 they they will be set to default.
I have found some examples dealing with pattern visibility and BOM structure, but not exactly what I need.
I've tried patching some code together but I'm far from experienced. Can't find solutions, but I can find errors.
Thanks in advance.
Dewayne
Inventor Pro 2023
Vault Pro 2023
