jamieking89
1500 Views, 8 Replies
iLogic rule for constraint suppressed/unsupressed dependant on active part
Good morning
I was wondering if anyone could help me with iLogic for constraints. I have an adaptive pipe, which dependant on which one of 2 plates in the assembly is un-suppressed will be constrained to its bottom face.
What is the ilogic syntax for this? And also is it best to have one constraint from the top of the pipe face which will change what face it is constraint too dependant on what plate is active, or is it best to have 2 constraints one of which is suppressed if the component relating to it is suppressed?
i have attached the components and assembly also.
Cheers
Jamie
