llorden4
in reply to: llorden4
Quite a bit more playing, the root of it all appears to be stemmed from some declarations...
Sub FlatPlanes
CreateFlatPlanes = False
Dim oDoc As Document = ThisDoc.Document
Dim oAsmCompDef As AssemblyComponentDefinition = oDoc.ComponentDefinition  'Error occurs here
At this point, I get this error after the file is saved..
 Error in rule: Plane Generator, in document: Plane Int Test.iam
Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
Making this document declaration change...
Sub FlatPlanes
Dim oDoc As AssemblyDocument = ThisDoc.Document
Gives me this error instead...
Object of type 'System.__ComObject' cannot be converted to type 'Inventor.ComponentOccurrence'.
For some reason, I am now getting errors when I try to declare a variable name for my assembly component definitions.
Autodesk Inventor Certified Professional
