04-16-2020
02:23 AM
- Mute
- Permalink
- Report
04-16-2020
02:23 AM
Bug: SilentOperation is most of the time not silient
I can produce this problem with a part that has the following 3 ilogic rules.
rule: [main]
Dim iLogicAddin As ApplicationAddIn = Nothing Dim iLogicAutomation iLogicAddin = ThisApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}") iLogicAutomation = iLogicAddin.Automation iLogicAutomation.RunRule(ThisDoc.Document, "with-Imports") ' msgbox 1: Does show iLogicAutomation.RunRule(ThisDoc.Document, "none-Imports") ' msgbox 2: Does show iLogicAutomation.SilentOperation = True iLogicAutomation.RunRule(ThisDoc.Document, "with-Imports") ' msgbox 3: Does NOT show iLogicAutomation.RunRule(ThisDoc.Document, "none-Imports") ' msgbox 4: Does show iLogicAutomation.SilentOperation = False iLogicAutomation.RunRule(ThisDoc.Document, "with-Imports") ' msgbox 5: Does show iLogicAutomation.RunRule(ThisDoc.Document, "none-Imports") ' msgbox 6: Does show
Rule [with-Imports]
AddReference "GDH.Inventor.iLogic.Utilities.dll" Imports GDH.Inv.iLogic.Utilities
Parameter("TEST") = Parameter("TEST") + 1 MsgBox("Test = " & Parameter("TEST"))
Rule [none-Imports]
' imports System.IOParameter("TEST") = Parameter("TEST") + 1 MsgBox("Test = " & Parameter("TEST"))
When i start the rule [main] i get 5 msgbox's. All msgbox's are shown when the iLogic-addin isn't in SilentOperation. But when the iLogic-addin is in SilentOperation then:
- the rule with the imports-statement does not show a msgbox like i would expect form SilentOperation.
- the rule without an import-statement does show a msgbox wich i would not expect.
it is a bit more complicated because the import statement should be to the namespace of a dll that is also loaded in the rule. for example the following import statement will not make the msgbox disapear.
imports System.IO
Jelte de Jong
Blog: hjalte.nl - github.com
